Hi experts,
I got a small problem with cost of item manufactured.
I had created and item a , b, c with each item cost as 10.
so with these 3 items i want to manufacture item x.
So what is the process for manufacturing.Sorry experts i have tried the process and i got the output but iam not getting cost so plz tell me the process of manufacturing as well as getting cost.
Sorry if i post long question. Thank u
What costing method are you using?
Assuming you are not standard then the following should work.
i) Consume the material in the production journal/consumption journal/.
ii) Report the output into stock.
iii) Finish the production order.
iv) Run the adjust cost item entry routine (assuming you have fully invoiced all the consumed parts from suppliers)
Thank u adam iam clear with your answer,but what exactly finish prod.order mean and how to do that
Functions - Change Status - Finished.
