i have a test card its like customer master when i am creating new record i have to create by pressing f3 then it is automatically recording a blank record in the tabel (even i add 10 rec one blank rec is there). why is that ?
In general Navision always clears the primary key of a record when creating a new one with “F3”.
There are several ways to assign a primary key to the record:
Keeping the primary key field empty and let the OnInsert trigger of the ta´ble to the rest for you (as done in Customer table).
For multiple field primary keys with an integer as last field in key (Line No.), set a filter to the other fields and utilize the “AutoSplitKey” functionality of Navision forms (see Sales Order Subform)
You can use the “OnNewRecord” trigger of the form to assign a value to the primary key.
And …
… please be more precise when asking your questions. It is not clear what you want to achieve.
