Dear Forum,
This is regarding the approval setup. I have set the document approval accoding to the requirements and ran a test report and they all seems to work just fine. But time to time I’m getting the error of"Import approval template". As I know there is no manually approval template process in Dynamics NAV 5.1.
Then I check the Approval setup table (table ID 452) in object designer and there is a change in the overdue template and approval template. In cronus demo company there is “*” sign in that field but in the company that we have created that sign is not there. I have tried to copy this sign into our databse but still no luck, I think this is a BLOB.
The approval setup is working from time to time but then its asking to import the template . Sometimes it works and some times it works only as far as sending approvals and approving. The orders arent getting released also. So I was wondering is this a system bug or something. Do you guys have any ideas on how to fix this problem? Would appriciate all the input that you can give me.
Many Thanks,
Chamil
