Problem Win98 - Navision 3.70
Hi, i try to install Navision 3.70 SQL to Windows 98 PC, but it doesn’t work. Has someone incured in the same problem. Thank you.
Windows 98 no longer a supported OS for Navision 3.70. Perhaps due to poor physical memory management and need for stronger, faster client hardware to support finsql.exe.
According to “system requirements” Windows 98 second edition should do it. But only running as single-user. A server has to run on at least Windows NT version 4.0, SP6a.
Windows98 will not be ceased until Navision 4.0 But what is the problem - what doesn’t work? Is it the installation itself or running the program - is it a crash or error message?
Maybe You’re not running second edition of W98. Otherwise 3.70 doesn’t work on W98.
