Problem while accessing help file from client end
Navision Attain 3.10 is working fine in Client-server architecture. But from the client end we are failing to access the in-built help file of Navsion. What will be the exact procedure to solve the problem?
hi I guess your help files are deleted some how from the installation language module folder, where the client is installed. Harikesh
