problem when i try install dynamics nav 2018
Hello
this message show to me
and this is installation log
=== Logging started: 2018/05/24 03:59:16 ===
— logging level: standard —
RegistrySearch: Id = ‘SqlServerInstalled’, checking registry key existence.
Id = ‘SqlServerInstalled’, Key = ‘SYSTEM\CurrentControlSet\Services\MSSQL$NAVDEMO’, Exists = ‘0’
RegistrySearch: Id = ‘SqlNCLIInstalled’, checking registry key existence.
Id = ‘SqlNCLIInstalled’, Key = ‘SOFTWARE\Microsoft\SQLNCLI11’, Exists = ‘0’
RegistrySearch: Id = ‘DotNetFxRelease’, searching for registry key value.
Id = ‘DotNetFxRelease’, Key = ‘SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full’, Value = ‘461808’
RegistrySearch: Id = ‘VstoInstalled’, searching for registry key value.
Id = ‘VstoInstalled’, Registry key not found. Key = ‘SOFTWARE\Microsoft\VSTO Runtime Setup\v4R’
RegistrySearch: Id = ‘PowerShell30Installed’, searching for registry key value.
Id = ‘PowerShell30Installed’, Key = ‘SOFTWARE\Microsoft\PowerShell\3\PowerShellEngine’, Value = ‘5.1.17134.1’
RegistrySearch: Id = ‘WindowsSearchInstalled’, checking registry key existence.
Id = ‘WindowsSearchInstalled’, Key = ‘SYSTEM\CurrentControlSet\Services\WSearch’, Exists = ‘1’
RegistrySearch: Id = ‘Excel14Installedx86’, searching for registry key value.
Id = ‘Excel14Installedx86’, Registry key not found. Key = ‘SOFTWARE\Microsoft\Office\14.0\Excel\InstallRoot’
RegistrySearch: Id = ‘Excel14Installedx64’, searching for registry key value.
Id = ‘Excel14Installedx64’, Registry key not found. Key = ‘SOFTWARE\Microsoft\Office\14.0\Excel\InstallRoot’
RegistrySearch: Id = ‘Outlook’, checking registry key existence.
Id = ‘Outlook’, Key = ‘SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\OUTLOOK.EXE’, Exists = ‘0’
RegistrySearch: Id = ‘Outlook15’, checking registry key existence.
Id = ‘Outlook15’, Key = ‘Software\Microsoft\Office\15.0\Outlook\Setup’, Exists = ‘0’
RegistrySearch: Id = ‘Outlook16’, checking registry key existence.
Id = ‘Outlook16’, Key = ‘Software\Microsoft\Office\16.0\Outlook\Setup’, Exists = ‘0’
RegistrySearch: Id = ‘VCPPSpLevel’, searching for registry key value.
Id = ‘VCPPSpLevel’, Registry key not found. Key = ‘SOFTWARE\Microsoft\DevDiv\VC\Servicing\12.0’
RegistrySearch: Id = ‘VCPPInstalled’, checking registry key existence.
Id = ‘VCPPInstalled’, Key = ‘SOFTWARE\Microsoft\DevDiv\VC\Servicing\12.0’, Exists = ‘0’
RegistrySearch: Id = ‘VCPP64Installed’, checking registry key existence.
Id = ‘VCPP64Installed’, Key = ‘SOFTWARE\Microsoft\DevDiv\VC\Servicing\12.0’, Exists = ‘0’
RegistrySearch: Id = ‘VCPP201764Installed’, checking registry key existence.
Id = ‘VCPP201764Installed’, Key = ‘SOFTWARE\Microsoft\DevDiv\VC\Servicing\14.0’, Exists = ‘0’
RegistrySearch: Id = ‘IISInstalled’, checking registry key existence.
Id = ‘IISInstalled’, Key = ‘SOFTWARE\Microsoft\InetStp’, Exists = ‘0’
RegistrySearch: Id = ‘IISWinAuthInstalled’, searching for registry key value.
Id = ‘IISWinAuthInstalled’, Registry key not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’
RegistrySearch: Id = ‘IISASPNETInstalled’, searching for registry key value.
Id = ‘IISASPNETInstalled’, Registry key not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’
RegistrySearch: Id = ‘IISASPNET45Installed’, searching for registry key value.
Id = ‘IISASPNET45Installed’, Registry key not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’
RegistrySearch: Id = ‘IISNETFXInstalled’, searching for registry key value.
Id = ‘IISNETFXInstalled’, Registry key not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’
RegistrySearch: Id = ‘IISNETFX45Installed’, searching for registry key value.
Id = ‘IISNETFX45Installed’, Registry key not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’
RegistrySearch: Id = ‘IISISAPEXInstalled’, searching for registry key value.
Id = ‘IISISAPEXInstalled’, Registry key not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’
RegistrySearch: Id = ‘HttpActivationInstalled’, checking registry key existence.
Id = ‘HttpActivationInstalled’, Key = ‘SYSTEM\CurrentControlSet\Services\WAS’, Exists = ‘0’
RegistrySearch: Id = ‘IISISAPIFIInstalled’, searching for registry key value.
Id = ‘IISISAPIFIInstalled’, Registry key not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’
RegistrySearch: Id = ‘IISREQSTFIInstalled’, searching for registry key value.
Id = ‘IISREQSTFIInstalled’, Registry key not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’
RegistrySearch: Id = ‘IISSTATICInstalled’, searching for registry key value.
Id = ‘IISSTATICInstalled’, Registry key not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’
RegistrySearch: Id = ‘WebComponentsPrerequisitesInstalled’, searching for registry key value.
Id = ‘WebComponentsPrerequisitesInstalled’, Registry key not found. Key = ‘SOFTWARE\Microsoft\Microsoft Dynamics NAV\110\Web Components Prerequisites’
RegistrySearch: Id = ‘IdentityFoundationInstalled’, checking registry key existence.
Id = ‘IdentityFoundationInstalled’, Key = ‘SOFTWARE\Microsoft\Windows Identity Foundation\Setup\v3.5’, Exists = ‘1’
RegistrySearch: Id = ‘IISAspNetCoreModuleInstalled’, searching for registry key value.
Id = ‘IISAspNetCoreModuleInstalled’, Registry key not found. Key = ‘SOFTWARE\Microsoft\IIS Extensions\IIS AspNetCore Module’
Configuring package. Id = ‘ARP’
MSI log file set to: C:\Users\A7MED\AppData\Local\Temp\setup.wix.msi.7.log
Done configuring package. Id = ‘ARP’ ReturnCode = 0
Configuring package. Id = ‘SQLEXPRESS’
Done configuring package. Id = ‘SQLEXPRESS’ ReturnCode = 16389
Rolling back MSI package. Id = ‘ARP’
MSI log file set to: C:\Users\A7MED\AppData\Local\Temp\setup.wix.msi.8.log
Done rolling back MSI package. ReturnCode = 0
ERROR: Package Microsoft SQL Server 2016 Express failed with error. See detailed message above.
=== Logging stopped: 2018/05/24 03:59:56 ===
It doesn’t fail installing NAV, but it fails installing SQL server.
Which OS did you install on?
Did you use “Run as administrator”?
I think the problem is .that NETframework 3.5 missing.
https://www.microsoft.com/en-us/download/confirmation.aspx?id=25150
I don’t think so. NAV 2018 requires .NET Framework 4.7:
https://docs.microsoft.com/en-us/dynamics-nav/system-requirements-for-microsoft-dynamics-nav
As Erik said, it fails installing SQL Express, but with the log information, I can’t say why failed.
Systems requirement sheet does not say that it require 3.5. But personally i have experienced problems with NAV 2018 and 3.5, so I always install it anyway.
Did you solve this issue??
I had a SQL install issue a few months back - and it worked after installing the 3.5 framework even though as Erik says it is not part of the System Requrements sheet.
