Problem: Read permission on virtual table "Windows Languages"
In the past I developed a solution in which I used an integer field in my setup (with a table relation) to store the Language Code from virtual table “Windows Languages”. It was a 3.7 native NAV. Today I reused this idea but when setting the table relation for the field in my setup I got an error "No read permission for table “Windows Language” " while saving the table. I also changed to my partner developer license without any effect. Interestingly I was able to create and run a form on this table. The system is a NAV 4.03 on SQL.
Any idea?
I have tested you scenario in a NAV 5.0 and it worked fine. Did you test it in NAV 5.0 ?
