Problem Navigating in XML DOM, Search for a Node and read text from Siblings
Hello everyone
The xml is an example of an xml data that can be loaded to Excel. When it is loaded In Excel you will get 2 worksheet one called “ARTIKEL_OCH_PRODUKT” and the other called “PRODUKTTEXTER.”
My data is split between the 2 Worksheets.
What I am trying to do is read sequentially each record in Worksheet=ARTIKEL_OCH_PRODUKT then perform a lookup using the PRODUKTID=731110 for the 2 descriptions which is held in the other Worksheet=PRODUKTTEXTER
I can’t get hold of the Siblings text after the search : Workbook/Worksheet[@ss:Name=“PRODUKTTEXTER”]/Table/Row/Cell/Data[text() = “731110”]
ARTIKELNUMMER
BENÄMNING
INFO
PRODUKTID
PRODUKTNAMN
BILDNAMN
PRODUKTKOPPLING_DUBLETT
1000-00-0017
731110
PRODUKTID
PRODUKTNAMN
PRODUKTBESKRIVNING
731110
and this****
CREATE(XmlDocL);
XmlDocL.async(FALSE);
sPathFileNameG := ‘C:\incadea\SI-Data\02 Web-Shop\Job6_20140314\XML_DUELLS\ATV.xml’;
XmlDocL.load(sPathFileNameG);
XmlNodeListL := XmlDocL.getElementsByTagName(‘Workbook/Worksheet’);
FOR iNodeListL := 0 TO XmlNodeListL.length - 1 DO BEGIN
XmlDomElimateL := XmlNodeListL.item(iNodeListL);
xmldomAttribL := XmlDomElimateL.getAttributeNode(‘ss:Name’);
IF NOT(ISCLEAR(xmldomAttribL)) THEN
cWorksheetNameL := xmldomAttribL.value
ELSE
cWorksheetNameL := ‘’;
CASE cWorksheetNameL OF
‘ARTIKEL_OCH_PRODUKT’: // ARTIKEL_OCH_PRODUKT
BEGIN
CurrNodeL := XmlNodeListL.item(iNodeListL);
XmlNodeList2L := CurrNodeL.selectNodes(‘Table/Row’);
// Skip First Headings which is first record
FOR iNodeList2L := 1 TO XmlNodeList2L.length - 1 DO BEGIN
CurrNodeL := XmlNodeList2L.item(iNodeList2L);
XmlNodeList3L := CurrNodeL.selectNodes(‘Cell’);
rItemL.“No.” := FindNodeItem(XmlNodeList3L, 0); // Item No
cProduktidL := FindNodeItem(XmlNodeList3L, 3); // Produktid
// Workbook/Worksheet[@ss:Name=“PRODUKTTEXTER”]/Table/Row/Cell/Data[text() = “731110”]
CurrNode2L := XmlDocL.selectSingleNode(STRSUBSTNO(
‘Workbook/Worksheet[@ss:Name=“PRODUKTTEXTER”]/Table/Row/Cell/Data[text() = “%1”]’
,cProduktidL));
// This Works
IF NOT ISCLEAR(CurrNode2L) THEN
IF NOT CONFIRM(STRSUBSTNO(’%1 : PRODUKTID %2’, iNodeList2L, CurrNode2L.text))THEN
ERROR(’’);
// I Can’t get the next nextSibling because it does not exits
CurrNode3L := CurrNode2L.nextSibling;
IF NOT ISCLEAR(CurrNode3L) THEN
IF NOT CONFIRM(STRSUBSTNO(’%1 : PRODUKTNAMN %2’, iNodeList2L, CurrNode3L.text))THEN
ERROR(’’);
END;
END;
‘PRODUKTTEXTER’: // PRODUKTTEXTER
BEGIN
MESSAGE(FORMAT(XmlNodeList2L.length));
END;
END;
END;
