It is already told that the transfer journal will not correct your issue.
You have done an issue with out receipt on specific dimension, in such case you need to create a receipt that probably matches your issue and do the issue with the correct dimensions.
You have not told how the original issue has been done?
we upload sheet first data export , then this sheet show in transfer journal and then we make some amend like ths called finical dimension then i post the transfer journal
after that i discover this problem and big deal is the item when i try to make any kind form transfer it show me 0 balance
That is just down to the dimension controls of the items and how you have configured the inventory model group to deal with negative inventory and the inventory dimension group to deal with physical stock. You can move stock you do not have if you configure AX to do it, but then you can put it back, your inventory warning was because you had not defined the dimensions required, even if in a transfer journal the answer is transfer batch 12 to batch 12.
