Problem in sharing Item details to other company using virtual company
Hi friends,
I am using Virtual company in sharing item details to others companies, but the problem is all the existing released product is gone and moved to the default company (DAT).
Chris
The virtual company has a different DataAreaId and existing records are not automatically changed to use that. You’ll have to do it yourself - and to resolve any conflicts that may occur if you merge data from more companies to a single one.
is there other way to share item details to other companies beside using virtual company?
You could keep items in existing companies and introduce some synchronization.
AX2012 uses shared definitions of products that are later released to individual companies. Technically it’s not sharing, but the intention is the same.
