problem in running report from TempTable
Hi
Can any body help me in running a ssrs report through running a job(X++ code).
Actually I am doing this because the table I am having is a temp table so I want to run the job into a single session for which I am inserting the data into the table and simultaneously i want to run a ssrs report fething the data from the temp table .
I have written the code as ,
static void insertdata(Args _args)
TestTable testTable;
DRV_TmpTableReport tmpTableReport;
SrsReportRun srsReportRun;
//SysQueryRun queryRun;
//ttsBegin;
tmpTableReport = new DRV_TmpTableReport();
select forUpdate testTable;
testTable.AccountNum= ‘5000’;
testTable.insert();
srsReportRun = new SrsReportRun (‘Report3.PrecisionDesign1’);
srsReportRun.init();
if( srsReportRun )
srsReportRun.executeReport();
but the report is not showing any data .Can anybody help me in this regard.
Abhishek Bhati
