Problem in Phys. Inventory Journals
When generating Phys. Inventory Journals for all my items, the Shortcut Dimension 2 Code does not came to Item Journal Line table. Why not?
Did you check the necassary Dims in By Dimensions form in Calculate inventory?
If you did, and still nothing shows up, Dims are NOT present in ILE lines, which the source of inventory.
Some docs have been posted with these Dims not filled in. Check if dims are set to mandatory.
PS and please do not cross post the same question in several forums… I deleted the other one.
