kindly if u can clarify the status of P.R and what is the valid mean ( tick mark or cross mark or without mark )
Thanks you so much for your kind reply
I think you get the red cross mark if there’s a budget validation failure, a pre-encumbrance error, something wrong with the quote, price tolerance problems, an invalid vendor selected, or any other type of critical error.
You’ll get a yellow warning symbol if the budget check passed with warnings.
If you get a green tick mark, the purchase req is approved and the budget check has passed. These approved purchase reqs can have POs created for them. Once you create a PO from this, you should see that record fall from the list.
If items aren’t showing up on that form, there might be an issue. I seem to remember there being some sort of hotfix released for R2 around the budget check process being required even if budgeting isn’t enabled, but I can’t remember for sure.
