Hi to all the dynamics users out there.
I got an problem in importing XML file that was exported through the very same dynamics NAV 5.0 solution.
The field is not in the primary key and in its properties I have changed its Not Blank Property to No.
Then also its not importing the XML file that contains the blank fields.
What should I do for that. Please suggest me.
Thanking you all.
