i have been trying to import Budget into Dynamics AX 2012 using Document Data Source: ‘Budget Register Entries’ (it comes from ‘BudgetService’ service group).
the error i kept getting is ‘index was outside the bounds of the array’.
what makes it happen to be error? and what is the solutions?
thanks in advance, any help will be really appreciated.
Riksa
Hi Riksa,
Did you find out what was this problem. I am facing a similar behaviour.
Regards
hrd
Hi Riksa!
Please see the explanation of this error posted here: http://ax2012exceldataimport.blogspot.com/2012/05/dynamics-ax-2012-excel-add-in-issues_23.html
The issue is caused by unhandled exception and the real issue reason can be seen in Event Viewer and/or Exceptions form in Dynamics AX 2012
I reproduced this issue with LedgerDimension field on BudgetTransactionLine record not specified
Please specify valid LedgerDimension field value for BudgetTransactionLine record being imported and import process will succeed
Best Regards,
/Alex
