When i’m following the manual for this particular excercise (Demonstration : Use the IF,EXIT, CASE and Compound Statements in Page pg 7-11 to 7-15) the following error in relation to the Result is popping up(after step 8 is worked out), I have re-checked all the workings in C/al editor but still the beneath error comes up
A value or an expression was expected. For example:
In the page designer, the actions should go all the way at the bottom, open it from the first empty line. You are looking at the actions from an existing line in the page designer. If you added actions from any of the other, you’ll have to open the action designer from each line in the page designer to see where it was added in the first place, and you’ll have to remove it from there, and add it to the action menu that belongs to the page object itself.
