Problem Expanding Database
Hi Twice now my customer has had an error message saying that he does not have enough space on his disc/diskette to expand the db. He is trying to increase the db by 6GB and has 10GB free on his drive. Has anyone had any similar problems? Or a solution?! Thanks Col
Read this thread it might help:- http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=3576
Colin, in any case, for performance reasons, the database partitions should be between 2 and 4 G. Before enaything else, youn need to get more hard drives. Please also check your drives to see how they are formatted. To go over 4 G you normally need NTFS, or a partitioning tool tha will allow larger files, but as I say this is irrelevant, since the actuall issue is that you do not have enough drives.
