HELLO ,
I just installed AX 2012 R3 on the server, all has been well, I install the instance of the database, the AOS and client, when I run the client I have a message error that displays “communication failure”: The server is not disponibe .Check your configuration and network connection and try again.
I check the services , when I start the AOS services: Microsoft Dynamics AX Object Server 6.3 $ 01-MicrosoftDynamicsAX12, an error message appears: Windows could not start the Microsoft Dynamics Server 6.3 $ 01 - MicrosoftDynamicsAX12 on local Computer.
I click on the AOS service properties, I check the path to the executable file access as shown in the photo, I can not find this folder on my server.
Thank you for helping me
Best regards
