Hi i am unable to deploy reports…i have installed AX 2012 on Win - 7 professional
everything was fine but i moved some objects of a report i had developed on other environment after that
i am not able to deploy reports none of the report deploy or run for that matter please check screen shot taken when report deployed
Don’t you feel that “AX Developer Forum AX 2012” wasn’t the best title for your question? I’ve changed it to “Privileges to deploy reports”; it sounds much more descriptive to me. The AX version is attached as a tag.
The error says: “You do not have privileges to deploy to server: alle-vtandel-pc. For deployment, you must have administrative rights to the SQL Server Reporting Services (SSRS) server. Contact your administrator to deploy.” It’s quite clear.
Do you have such permissions?
