Hi Following problem: when a report is set to be printed on screen and afterwards I click on the “Print” button, the report is printed correctly on the printer. But: when the report is set to be printed directly on the printer and I start the printout, Axapta crashes. The Event Log shows the following entry: “Faulting application ax32.exe, version 3.0.1951.3733, stamp 40d9c293, faulting module ax32.exe, version 3.0.1951.3733, stamp 40d9c293, debug ?0, fault address 0x0006e0d4” The crash happen at printout with 3-tier as well as with 2-tier client. I have debugged the report and what I can also say is that the crash actually happens AFTER the print command, so it seems it happens when the printout command to windows has been finished (when Axapta thinks that it has made everything). Somehow I think it’s more a Windows and not an Axapta problem. What would you say? Thanx for answers.
