Printing reports from print preview
I have a little problem about printing reports from print preview. There are some reports that I Cant’t print on printer from print preview. Does anyone know why ?
Hello! I believe this applies to documents (Such as the sales shipment) which update data in Navision when they are printed (e.g. the No. Printed field). As the report has already been run to preview, it cannot then write back to Navision, so this is probably why it is blocked. Hope this is of assistance. -------------------------------- Edward Bloomfield Navision Support Consultant Cambridge Online Systems Limited www.cambridgeonline.net
Edward is right. You can see in the C/AL code, if the report will print from preview or not. If the command CurrReport.PREVIEW is used anywhere in the C/AL code of the report, it will not print from the preview.
