Printing problem using WTS
We are using WTS for remote access of Navision. Laser printers are install at WTS clients on USB pots. We are unable to take print outs of navision reports on the clients. Plz suggest the solution.
Well, I would say the TS does not know any printer, for the TS they are not accessible. You have to install every Client Printer on the Terminal Server, then you can access them.
Install the Printers as IP printers with a specific IP address, and then they are easy to access. Just watch out for bandwidth.
thanks for your suggestions. can you explain me how i Install the Printers as IP printers with a specific IP address?
Thats not really in scope here, but the easiest is to just go out and buy some IP printer boxes, they are the cheapest solution. Other than that you would need to use specific IP addresses for you clients that the printers are connected to. If you are starting from scratch, then the best solution is to by printers with IP ports built in. Just about all printers made these days have this option.
