I have a client requirement that he wants to get the image of consumer to be printed on report .This image is stored in a folder with unique name .The format of immage file is bmp. on some blogs it was written to check The reports tutorial_GraphicsCustBalanceList and Tutorial_sushiInvoice demonstrate how to print images.but i could not see these in my instance of ax2009 were can i get these…
But my requirement is quite complex. In my report For eg. I have a report with 5 pages content. After each pages one bitmap image should be added. So that report now contains 10 pages.
Note1: That 5 Different Bitmap images should not in page header,page footer section. It should be visible as in one page. And it’s not a company logo.
Note 2: Bitmap images should be included thorough codes and not by specifying with image name property.
You can try to add a programmable section that displays your image, this section could be triggered each time a new page is created, the problem will be to check when a new page is added, it will be manageable if you use a fetch() method but if not, I have no ideas the following links might help you:
