Printing Barcode Labels
I am trying to write to a TEC B482 printer. Unfortunately the manual is very large and taking some getting through. Has anyone worked with one of these barcode printers before, and if so could you point me in the right direction as where to start, and what has been found to be the best solution. Thanks in anticipation
Never worked with that kind of printer, but worked with barcodes in Navision with standard printers. Using standard printers you only need to define the label/text on the report (as usual) and choose for them a barcode font instead of the standard one (remember having installed the barcode font in the computer previously) on the report. Hope it helps you,
