In General Ledger Setup, you can define specific printers for reports. Once you select the user and report, you can then use the assist button to show the printers for this user. Can anyone tell me which table this printer info is in? We are using 2.01b. Any help would be welcomed. [:)]
Disregard, I see that it is reading directly from the workstation. We are having a problem with Citrix clients via WAN.
Hi John, Navision stores the printer information in Printer (System table). From there you can retrieve the printer information.
