We would like to print signitures on all of our checks during the check printing process. Does any have suggestions for a effecient and secure way of doing this. Thanks.
As a suggestion - Add signature (blob) to user set-up. Restrict access to import/export Add blob to cheque report. Add code to read in signature of current user Add code in report to only users with signatures to print cheques. Is there a limit to user’s cheque value? This would complicate matters a little. Regards
If you are interested in a 3´part product LaserNet overlay could solve this. LaserNet will scan all documents/reports/batch files from Attain/Financials, and every time you print a check, LaserNet will fill out the check, insert the right signature at the right place.
