Print Problem In Dynamics Ax
hi all,
I Write a Code To Print A Report In Ax
i write this code
args.name(reportstr(ReportName));
reportRun = classFactory.reportRunClass(args);
reportrun.run();
open this form, i Dont Want , Open This Step Of Print And Directly show Print Preview
plz Help Me
You need to add a parm to launch your report preview, you can try to add the following in your code:
reportRun.args().parm(yourParm)
Hope it helps, please verify solution if it solves your problem
regards,
Thomas
