Hello,
here are my questions: Can I print existing pdf files with an aos printer using AX 2009? If so, how?
I have to say that adobe is not installed on the aos, so as far as I know I can’t use WinApi::ShellExecute to print on aos?
Basically I have to print files from the document management with a cover(AX Report) to the fax server.
As I started I thought of 2 ways to get it done:
- Add the pdf as image or something like that to the report and print it directly with the aos fax server.
- Print the report as pdf, merge the pdf files(cover and document management files) and send them as one file to the printer.
I can merge the files with the pdfone dll but I don’t know how to print that file.
