Print Management Settings
I’m trying to set up print management in AX2009 with Outlook 2007, but the email address I enter into the print management settings doesn’t flow through to the posted invoice / email. Instead it is populated with “Enter name here.” even though the subject line has come through with the PDF invoice. Has anyone else had this problem before and what was the resolution please?
Cheers
Jon
Hi Jon, did you figure out the issue with enter name here in the emails to address field? i am fairly new to AX and i have run into this problem. Not much on the internet about it.
tim
