I am trying to print Barcode Labels from Dynamics AX Retail. (Retail > Periodic > Barcodes and Labels > Print Product Labels).
The system is giving me error ‘No store has been set up.’
hi
if it’s not solved yet; you can follow the below steps:
1- go to retail shared parameters > general > local store : select store number
2- go to retail shared parameters > labels> Product labels : select which stores that you want to print labels for
3- go to barcode and labels Product barcode: and select the report name
4- now the form should open but you will not be able to print label for a product that doesn’t have a product label in it’s setup
I suggest to follow this link for more details : https://technet.microsoft.com/en-us/library/hh597174.aspx
go to retail shared Parameter > general > select the store
