Hi ,
How to store image in nav table. and how to print that image in report.
Hi ,
Please check Company Information table…how Picture field is Used
Store the image in a BLOB field and use calcfield in the report to show the image.
If you want detail then check the Company Information or Item table & forms.
I took blob datatype. in that field how to store.
that’s how to store . May I give image path or what in that field.
Storing image in Nav database will increase your DB size .So I suggest store the path of image file in field
P.S. Copy all images on common server from where you can access anytime.
