Print empty section
How to print the section in report which contains no data from its DataItem?
Make a temporary variable of the type of the dataitem you’re wanting to use, fill that temporary variable with the records you’re wanting to print and if there is none, fill it with one empty record. Then modify your report for using that temporary variable in an (for example) integer dataitem that will be the one that prints your sections instead of the original dataitem. Regards, Alfonso Pertierra (Spain)apertierra@teleline.es
