print diagram from document handling
I setup the document handling for “File” type using the “Archive directory”. Let say the folder is store in C:\Temp. I attach a jpeg file to an item. AX will auto upload jpeg file to the destinate folder.
I want to create a report of the item and also print the jpeg diagram. Do any have any class or method that i can use to print diagram from external folder?
Pls advice.
Make use of this code
display DocuValueFile ItemImage()
DocuRef docuRef;
DocuValue docuValue;
BinData binData = new BinData();
DocuValueFile fileVlaue;
DocuType docuType;
select firstOnly docuRef where
docuRef.RefRecId == InventTable.RecId
join fileName,fileType from docuValue where
docuValue.RecId == docuRef.ValueRecId;
select ArchivePath from docuType where
docuType.TypeId == “File”;
if(docuValue)
binData.loadFile(docuType.ArchivePath+docuValue.FileName());
fileVlaue = binData.getData();
return fileVlaue;
Thanks Kranthi, i will try it.
it works. thanks a lot.
