I can open a XML formatted invoice with this command at IE:
winapi::shellExecute(FileNameSaveXml);
I want to just print silent and don’t show IE. How can I do this?
What about using WebBrowser.Print() via .NET Interop? Here is an example: How to: Print with a WebBrowser Control.
Can I use this from AX or should I create a .NET DLL?
I think you’ll have to subscribe to DocumentCompleted event and therefore you’ll have to wrap it in class library.
I come to there but I couldn’t fit “webBrowserForPrinting.DocumentCompleted += new WebBrowserDocumentCompletedEventHandler(PrintDocument);”
in X++, just run without any print.
System.Windows.Forms.WebBrowser w = new System.Windows.Forms.WebBrowser();
u = new System.Uri(filename);
w.set_Url(u);
w.Print();
return;
we created a .net .exe and it worked for us, thank you…
