I want to PREVIEW a report directly on a PUSH button without the request form. Stéphanre VABOIS
There is a property on the report - UseReqform. Set it to no. Regards, Mark
If you set the ReqForm to “No” the code will run the report automatically— but it still won’t Preview: instead, it will Print (i.e., it will print to a printer.) You could have the report print to a file and then look at the file with a text editor, or you might be able to save the output as HTML and then look at it with your web browser. --Tim Horrigan tim.horrigan@emsolution.com ------- Tim Horrigan
