Dear Experts
i have got this problem in all my txn i.e sale ,purchase,prepayment,
You must specify Prepayment No. Series in Purchase Header Document Type=‘Order’,No.=
Please help me
Dear Experts
Please help me
Use the debugger to find out the reason of this error.
Are you using Pre-payment functionality of the product? Check if “Posted Prepayment No. Series” is defined in Sales & Marketing , Purchase Setup
Thanks Dhan sir
I am using Navision 2009 Sp1 and i also defined in both setup still problem is same
SalesHeader.COPY(SalesHeader2);
WITH SalesHeader DO BEGIN
IF NOT CONFIRM(Text001,FALSE,“Document Type”,“No.”) THEN
EXIT;
SalesPostPrepayments.CreditMemo(SalesHeader);
IF Print THEN
GetReport(SalesHeader,1);
COMMIT;
SalesHeader2 := SalesHeader;
END;
In addition to wat danraj said
just check whether the Prepayment No. Series field is filled in or not in
Purchase Order Form → Prepayment tab.
hii
Ravi thanks for reply it work ,can u told me plz how this situation occur .It is due to No series relationship or some other ,please specify
Regards
Hi Vikas
Actually it doesn’t happen. it automatically fills against the Prepayment invoice no.series in Purchase & Payables setup.
so its better to check the field is filled in or not before posting. so put a test field over ther.
hii Ravi
in my case here also i mannully filled and after that it post not gentrate automatically i want as default feature of Navision ,please guide me to do same
In the purchase header table ON INSERT Trigger just get the purchase setup table…
i.e PurchaseSetuptable.GET;
enough.
Purchases & Payables Setup.GET (Table 312.GET)
hii
Ravi thanks for reply bt sorry it not worked
Hi
It seems the setup parameter and number sequence problem
