I have a report that I want the filtering to be pre-populated with the currently selected record when it is run.
The report is based on a different table to the one that is used on the form/page.
In my form I have this code:
l_InterfaceProcessLogDetail.SETFILTER(“Log ID”, ‘%1’, ID);
REPORT.RUN(REPORT::“Interface Process Log”, TRUE, TRUE, l_InterfaceProcessLogDetail);
And when I click the button in the classic client this works perfectly.
The code gets transformed into the page correctly, but when I click the button on the page, it does not apply the filter to the Log ID field.
Has anyone come across how to do this yet?
I took a look at how this works on the Posted Sales Invoice, but unfortunately that is using CurrPage.SETSELECTIONFILTER(SalesInvHeader); and then passing the SalesInvHeader to the report.
Maybe this is the trick to make it work, but I can’t do this because I am running the report on a different table, and so SetSelectionFilter is no good for me.
OK mystery is solved. I ended up using the reportvar.**settableview(**table) code and it works a charm, but it didn’t at first and I suspect the reason for this was why the Report.RUN with a record parameter didn’t work. It was nothing to do with the potential differences between the RTC and Classic client, but was instead a dumb programming error. [:$]
I originally had a OnPushAction property against me menu button in the classic client and when I realised I couldn’t pass the current record (since they are on different tables) I put the code in the OnPush() trigger instead - but by mistake I left the properties set. Then when I transformed the Form to an RTC page, the properties were being executed and not my code - hence the record filtering was never being passed. I only spotted this because the Classic client will actually run the report twice - once for the properties against the button and once for the code, whereas the RTC only ran the report once - for the properties.
