My company has some divisions. When request some item via PR, it must approve by their own division’s heads base on the item that the divisions requested.
you can configure the Purchase requisition workflow using the “condition decision” elemenent. “purchaserequisition.lines.Defaultdimensions.Department” - value “X” then route it to “Approve” activity for which you can assign approver X.
For the “condition decision” -false node you route it to another condition of checking whether the department is “y”…
I still confuse. Because i have a lot of division. And the approver is the head of each division.
As you said use the condition decition, in this element i set ““purchaserequisition.lines.Defaultdimensions.Department is value X””, how can i set the approver?
So the head division know that he must approve the PR
It seems that the condition decision only have true or false.
So my scheme is
If the department ‘X’ then the approver is ‘X’
else if the department is ‘Y’ then the approver is ‘Y’
else end.
I make it using alot of condition desicion.
Sorry , i have another question, how can i set more than one approver. I have one condition decision and it need to 2 approver. it seems in approver purchase requisition only have one final approver
