PR to PO conversion batch
Batch setup to auto convert PR to PO and still waiting. Please advice either to auto convert the PR into PO OR to manually manually enforce the batch from PR to PO. Thanks!
Does the other batch jobs running? Check if the batch server is assigned to the batch group (check the batch group on the batch task)
Hi Kranthi…Non of them are running. Batch server is assigned though, please see below.
Any tips on enforcing manually?
I have followed all steps as advised below.
https://daxing2012.wordpress.com/2013/01/16/automatic-creation-of-purchase-order-when-the-pr-is-approved/
If so then it could be an issue with the configuration.
Check if at least one of the the servers assigned to the batch group is marked as batch server.
