Posting Invoice in Sales Order
hi experts
can you help me??i can’t posting invoice if i create sales order with code project but if i create sales order without code project button posting invoice is enabled. why??please help [:)]
Intan
It need to be done from the Projects.
http://technet.microsoft.com/en-us/library/aa600958.aspx
Hi Kranthi,
Thanks for your solution, but i use ax 2009
can u help me with another solution??
Intan
The solution is the same, you need to run the invoicing process through the projects module.
Why is this set to projects if you do not understand what they are? I am confused!
