Just wondering whether anyone has seen this issue before.
When I try to post inter-company sales order invoice it fails with following error -
The state of the source document or source document line could not be updated Removal of suspension of recId allocation for table VendInvoiceInfoTable has failed.
The sales order invoice gets posted correctly. But the above error is thrown when system tries to update Purchase order invoice and the process fails with above error.
Any tips/suggestions to resolve above error would be appreciated.
We ran in to the same issue with Feature Pack + CU5 on our QA environment. A bright engineer on our team realized that the CU5 update for the AOS had not been performed, while all of the data and code upgrades were completed.
This resolved our errors.
I debugged the CIL for some time and realized that some assemblies were missing. Also, after an AOS restart the XppIL folder would be rather small in size. After the AOS was updated, restarts didn’t impact the generated IL files.
do you get any solution on this from Microsoft? i am also having same issue.“Removal of suspension of recID allocation for table VendInvoiceInfoTable has failed”
