Posted Transaction
Hello There,
How can i add Text column in Mov Journal or Transfer Journal in AX 2012 in order to add any Description?
Regard,
Ally
same I have implemented in AX2009. Is this going to help you …plz inform
What is the issue in adding a field to form? Please elaborate on the title, as your problem has less relative explanation.
http://msdn.microsoft.com/en-us/library/aa609505.aspx
Dear Kranthi,
I want to add the text field in Mov Jour, Transfer Journal or other forms in AX 2012, where the user can add the Description or Purpose of Creation.
Hope this explanation will be enough to understand my problem…[:)]
Ally
You already have a field in journals to show the description. By default it takes the description from the journal names, still you can modify it.
