Posted time
How do I get “item ledger entry table” posted time?
Hi Barathy,
The only ‘time’ instance recorded when creating ledger entries(in standard NAV) is the Creation Date on associated Register tables. If you need to have a real time registered you will need to have that programmed.
Are you looking to add a “Posting Time” field?
Yes, I need to add posting time field.
what type of field do I select?
May we ask why you need such a field? You’re not goinf to be able to change it so why isn’t the DATE enough?
You’ll have to add this field to posting CU’s and with a question like “what type of field do I select” makes me feel that this isn’t a change you should be making since the answer is “TIME”. Your nav partner should make it if you actually need it.
