Dear All,
Does any one know what will happen in module production if the posting phisycal inventory and financial inventory is not selected in item model group ?
Is it required ?
In what kind of condition that both of them should be selected ( espesiallly in production site) ?
Thanks in advance
Regards
Rudy
Parent or component?
Parent - Financial. it would mean it does not cost at the unticked level, so if you do not cost at warehouse it holds cost by sit.
Component - It will cost at the level defined again.
Parent - Physical not checked will book no physical stock in, but it has to be ticked by site so it will not matter
Component - It checks you have enough stock, so if you are consuming from WH1 in Site1 and need 10 but have 0 but at the same time have 10 in your reject warehouse in Site 1 but you did not check physical by warheouse it would let you consume 10.
Hi Adam,
Thanks for your reply.
Is it parent a finish good ?.
For financial inventory, i still don’t understand the effect if i clear in financial inventory in item model.
Thanks in advance
Regards
Rudy
Yes parent is a finished item
Create 2 Items, costing method FIFO. Flag 1 as financial at Site and Warehouse, flag the other as just financial at site.
Do the following for both items.
- Raise a purchase order for the item with 2 lines.
- First line book into site 1 warehouse 11 and book it in at $5
- Second line book into site 1 warehouse 12 (or another in 1 not 11) and book in at $10
Now go to the onhand screen and show the site and warehouse dimensions. In each case you have 1 in stock.
Look at the cost field. Item 1 will have a cost of $5 at warehouse 11 and $10 at 12 as you are costing by warehouse.
Item 2 will have a cost of $7.50 bacause you are not costing be warehouse, just site and at the site you have 2 at $15 total which is $7.50
