post packing slip from inventory management module
Hi There,
Suppose the warehouse staff post the packing slip from inventory module by path “Inventory management->Common->Shipments”, on the shipments form, select a record and from the “Functions” menu button, select the packing slip menu item.
The problem is if we don’t select “Print packing slip” on the posting dialog, we cannot get a second change to print the packing slip from inventory management module again.
My Questions:
  1. Is it a good idea to ask the warehouse staff to post the packing slip from “Inventory management” module?
  2. is there a way to print the packing slip again from the “Inventory management” module?
many thanks.
Can you try this option…
Sales & Marketing → Inquiry → Journals → Packing Slip ->Preview / Print
Hope it solves your purpose.
Prabu
Don’t forget to the post(s) that solved your problem
Hi Prabu, we need to post it from inventory management module.
thanks.
Hi
I think it not possible in the Inventory and Warehouse Management. You have to go to Sales & Marketing and pick the required packing slip and can take a print out.
Leave this in the forum and we can get suggestion from experts for a workaround method.
Prabu
If your intentions is that the user shouldn’t see the other modules, you can think of putting a copy of this menu item in your Inventory management module. What you should make sure is …is that ok that the user sees the information that is available in this menu item?
Hi
add packing slip journal inquiry form to specific user favorites and setup appropriate security rights such that he should not see unrelated modules or forms.
Srinivas
Hi
Srinivas
