Hi there ,
I am able to post one line in journal but when there multiple lines in the journal, I am unable to post
Please HELP
static void Posting3(Args _args)
InventJournalTable inventJournalTable;
InventJournalTrans inventJournalTrans;
InventJournalNameId inventJournalName;
InventDim inventDim;
InventJournalId inventJournalId;
JournalCheckPost journalCheckPost;
//Below code creates journal header
inventJournalTable.clear();
inventJournalName = ‘IPL’;
inventJournalTable.initFromInventJournalName(InventJournalName::find(inventJournalName));
inventJournalTable.insert();
//Below code creates journal lines
while select * from inventJournalTable
where inventJournalTable.Posted == 0 &&
inventJournalTable.NumOfLines!=0
if(inventJournalTable.RecId)
inventJournalId = inventJournalTable.JournalId;
inventJournalTrans.clear();
inventJournalTrans.initFromInventJournalTable(inventJournalTable);
inventJournalTrans.TransDate = systemDateGet();
select firstOnly * from inventJournalTrans
where inventjournaltrans.JournalId == inventJournalId;
inventJournalTrans.ItemId = inventJournalTrans.ItemId;
inventJournalTrans.initFromInventTable(InventTable::find(inventJournalTrans.ItemId));
inventJournalTrans.Qty = inventJournalTrans.Qty;
inventDim.InventSiteId = ‘XXX’;
inventDim.InventLocationId = ‘XXX’;
inventJournalTrans.InventDimId = inventDim::findOrCreate(inventDim).inventDimId;
inventJournalTrans.Voucher = ‘XXXX’;
inventJournalTrans.insert();
//The below code posts the journal
journalCheckPost = InventJournalCheckPost::newPostJournal(inventJournalTable);
journalCheckPost.run();
