Hi. In 3.10 it isn’t possible to post and print an item journal if You use Item tracking. This is fixed in 3.60. But has anyone done it in 3.10? Thanks in advance. /Lars
Anyone?
I don’t see a problem. What error ?
When You use Item Tracking in Item Journals You can’t use “Post and Print”. Your journal will be posted, but You wont get any printout. This is a documented bug in 3.10 that is solved in 3.60. But since Item Tracking has a quite changed structure in 3.60, it isn’t so easy to take those changes into 3.10. //Lars
