Positive pay standard functionality in AX 2012 R2 CU7
Hi Forum,
I am facing one issue while setting up standard positive pay functionality in AX 2012 R2 CU7. I have referred the below Technet link for setup and configuration:
http://technet.microsoft.com/en-us/library/dn269119.aspx
I’m not able to get output Positive Pay file in the output folder as specified. I have used one of the XSL file available in above link as example itself but it does not working. As it does not throw any error, I am not being able to debug the problem. Any suggestions or link to the solution would be appreciated.
Nitin
did you check the log information of the batch job ?
Hi Nuno,
Yes, we have checked those details. Also in Bank & Cash Management module-> Inquires section we had get details of all Positive Pay file status as Sent but not able to get actual Positive Pay file in specified output folder.
Nitin
Hi Nitin, could you resolve it…? Actually, I am also stuck into a similar situation, where a blank output file is being generated.
If you were able to get this resolved, please share the steps.
Thanks a ton!
Aman
