Can someone throw some light on this error. I tried to delete line by line and got an error on every line.
Dimension Code product must not be mentioned…?
Check your dimension setup. That error trips when the dimension’s “Value Posting” is set to “No Code”.
I am looking at Financial management, setup, dimensions but i do not see value posting…
I am using 2009 SP1
Run it through the debugger. It’ll stop where you get the error message and that should give you a pretty good idea what needs to be done
Cancel the Line Dimension with PRODUCT , on Job Journal line 120000. (Button : Line > Dimension )
One of the Default Dimension (on G/L or Item or Cust / Vend …etc) has been set PRODUCT to No Code on Value Posting.
Exactly what Babrown and Rics mentioned! I just couldn’t find the correct spot
On table 27, Default Dimension the value posting was set to no code for the product dimension…
THANKS!!
