Maybe I missed this in the release documentation but it seems that one of the new features in 3.7 is the ability populate source expression property values from the symbol menu without having to use use the old copy & paste trick. Anybody noticed any other little gems?
Hi, yes,you are right.If you open the Navision 3.6 version database using Navision 3.7 fin.exe, you can also do the same thing.
Chris Yes this is a make life easier feature. When on the SourceExpr Value field you just press the Assist edit button and up pops the F5 symbol menu, you selet the field/Variable you want and press return, easy. No more copy and paste or masses of misspellings.
